Flexible Integration of Service Suppliers in Collaborative Service Procurement Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Maik Herfurth
  • Fonction : Auteur
  • PersonId : 1007869
Thomas Schuster
  • Fonction : Auteur
  • PersonId : 992756
A new conceptual design for service procurement networks may surpass existing limitations and bottlenecks. Thereby efficiency can be improved and transaction costs be reduced. To overcome existing limitations a design approach is presented that supports enterprise application integration based on master data and company-wide business process integration. Master data is harmonized with standardized data types and service-oriented architectures (SOA). eBuS-XML is introduced, in the proposed solution it serves as service-specific XML-based library for transaction data types, storage and integration of service e-procurement order processing.
978-3-642-23330-2_10_Chapter.pdf (80.04 Ko) Télécharger le fichier
hal-01569966 , version 1 (28-07-2017)
Paternité
Maik Herfurth, Thomas Schuster, Peter Weiss. Flexible Integration of Service Suppliers in Collaborative Service Procurement Networks. 12th Working Conference on Virtual Enterprises (PROVE), Oct 2011, São Paulo, Brazil. pp.85-92, ⟨10.1007/978-3-642-23330-2_10⟩. ⟨hal-01569966⟩
62 Consultations
104 Téléchargements
