Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : Securing embedded control systems presents a unique challenge. In addition to the resource restrictions inherent to embedded devices, embedded control systems must accommodate strict, non-negotiable timing requirements, and their massive scale greatly increases other costs such as power consumption. These constraints render conventional host-based intrusion detection – using a hypervisor to create a safe environment under which a monitoring entity can operate – costly and impractical.This paper describes the design and implementation of Autoscopy, an experimental host-based intrusion detection system that operates from within the kernel and leverages its built-in tracing framework to identify control flow anomalies that are often caused by rootkits hijacking kernel hooks. Experimental tests demonstrate that Autoscopy can detect representative control flow hijacking techniques while maintaining a low performance overhead.
https://hal.inria.fr/hal-01571779 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Thursday, August 3, 2017 - 3:03:57 PM Last modification on : Wednesday, August 14, 2019 - 11:24:04 AM
Jason Reeves, Ashwin Ramaswamy, Michael Locasto, Sergey Bratus, Sean Smith. Lightweight Intrusion Detection for Resource-Constrained Embedded Control Systems. 5th International Conference Critical Infrastructure Protection (ICCIP), Mar 2011, Hanover, NH, United States. pp.31-46, ⟨10.1007/978-3-642-24864-1_3⟩. ⟨hal-01571779⟩
