Analysing Enterprise Models from a Fractal Organisation Perspective - Potentials and Limitations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Kurt Sandkuhl
  • Fonction : Auteur
  • PersonId : 977635
Marite Kirikova
  • Fonction : Auteur
  • PersonId : 1002487
The paper focuses on the use of the fractal paradigm in enterprise modeling. It investigates whether the properties of fractal organizations can be applied in business analysis and whether this results in useful outcomes and new insights. Based on an adaptation and operationalization of properties of fractal organizations, two real-world cases are analyzed using the adapted properties. The contributions of this paper are (1) to adapt fractal organisation properties for use in analysis of enterprise models, (2) to present practical examples from two cases showing the application of the fractal organisation properties, and (3) to identify potentials and limitations of using fractal organisation perspective in enterprise model analysis.
978-3-642-24849-8_15_Chapter.pdf (76.21 Ko) Télécharger le fichier
hal-01572393 , version 1 (07-08-2017)
Paternité
Kurt Sandkuhl, Marite Kirikova. Analysing Enterprise Models from a Fractal Organisation Perspective - Potentials and Limitations. 4th Practice of Enterprise Modeling (PoEM), Nov 2011, Oslo, Norway. pp.193-207, ⟨10.1007/978-3-642-24849-8_15⟩. ⟨hal-01572393⟩
96 Consultations
535 Téléchargements
