Open Work of Two-Hemisphere Model Transformation Definition into UML Class Diagram in the Context of MDA - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Oksana Nikiforova
  • Fonction : Auteur
  • PersonId : 1014440
Natalja Pavlova
  • Fonction : Auteur
  • PersonId : 1014441
Model Driven Architecture (MDA) is based on models and distinguish between a system functionality specification and this specification realization on a given technological platform. MDA consists of four models: CIM (Computation Independent Model), PIM (Platform Independent Model), PSM (Platform Specific Model) and code model, all these are parts of the MDA transformation line: CIM->PIM->PSM->code. A PIM model has to be created using a language which is able to describe a system from various points of view, system behavior, system’s business objects, system actors, system use cases and so on. Current paper discusses the application of two-hemisphere model for construction of UML class diagram as a part of PIM. Several solutions for determination of elements of class diagram from two-hemisphere model are currently researched and described in the paper. As well as application of the transformations by example of insurance problem domain are presented in the paper.
978-3-642-22386-0_9_Chapter.pdf (1.06 Mo) Télécharger le fichier
hal-01572536 , version 1 (07-08-2017)
Paternité
Oksana Nikiforova, Natalja Pavlova. Open Work of Two-Hemisphere Model Transformation Definition into UML Class Diagram in the Context of MDA. 3rd Central and East European Conference on Software Engineering Techniques (CEESET), Oct 2008, Brno, Czech Republic. pp.118-130, ⟨10.1007/978-3-642-22386-0_9⟩. ⟨hal-01572536⟩
72 Consultations
65 Téléchargements
