Service-Based Realization of Business Processes Driven by Control-Flow Patterns - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Petr Weiss
  • Fonction : Auteur
  • PersonId : 1014464
This paper deals with Service-Oriented Analysis and Design (SOAD). SOAD comprises requirements elicitation, analysis of the requirements to identify services and business processes and finally implementation of the services and processes. It is a heterogeneous approach that combines a number of well-established practices. The key question in SOAD is how to integrate the practices to model a true service-oriented system with all its requirements. The approach presented in this paper helps to bridge the semantic gap between business requirements and IT architecture by using a method for transformation of business process diagrams into service diagrams. The service diagrams describe how the process is realized by using services. In details, the method transforms diagrams denoted in Business Process Modeling Notation into a set of UML diagrams. The principle of the method is demonstrated in an example.
978-3-642-22386-0_7_Chapter.pdf (281.89 Ko) Télécharger le fichier
hal-01572549 , version 1 (07-08-2017)
Paternité
Petr Weiss. Service-Based Realization of Business Processes Driven by Control-Flow Patterns. 3rd Central and East European Conference on Software Engineering Techniques (CEESET), Oct 2008, Brno, Czech Republic. pp.91-102, ⟨10.1007/978-3-642-22386-0_7⟩. ⟨hal-01572549⟩
63 Consultations
75 Téléchargements
