Abstract : Protein domain structure classification systems such as CATH and SCOP provide a useful way to
describe evolutionary structure-function relationships. Similarly, the Pfam sequence-based
classification identifies sequence-function relationships. Nonetheless, there is no complete
direct mapping from one classification to another. This means that functional annotations that
have been assigned to one classification cannot always be assigned to another. Here, we
present a novel content-based filtering approach called CAPS (Computing direct Associations
between annotations of Protein Sequences and Structures) to systematically analyze multiple
protein-domain relationships in the SIFTS and UniProt databases in order to infer direct
mappings between CATH superfamilies, Pfam clans or families, and SCOP superfamilies. We
then compare the result with existing mappings in Pfam, InterPro, and Genome3D.
Seyed Ziaeddin Alborzi, David Ritchie, Marie-Dominique Devignes. Using Content-Based Filtering to Infer Direct Associations between the CATH, Pfam, and SCOP Domain Databases. ECCB 2016, Sep 2016, The Hague, Netherlands. ⟨hal-01573093⟩
