Preprints, Working Papers, ...
EnMonitor: Experimentation over Large-scale Semantically Annotated Federated IoT data environment
Abstract : IoT applications are usually built on top of proprietary platforms that collect data from IoT devices. Furthermore, most applications rely on proprietary datasets, coming from their own sources. Thereby needing to deal with issues like interoperability and heterogeneity in the data. A solution is to add another layer (a platform in the middle that addresses the above-mentioned issues) and then build applications that use data made available via such platforms. As a proof of concept, we present EnMonitor, a prototype application, that is built on top of one such platform, called FIESTA-IoT. The application provides citizens with an understanding of the environment they live in with both local and global surrounding view.
Document type :
Complete list of metadata
Cited literature [6 references]  Display  Hide  Download
https://hal.inria.fr/hal-01579413
Contributor : Agarwal Rachit Connect in order to contact the contributor
Submitted on : Tuesday, January 23, 2018 - 2:11:54 PM
Last modification on : Tuesday, January 11, 2022 - 11:16:04 AM
Long-term archiving on: : Thursday, May 24, 2018 - 12:10:47 PM
File
fiesta-iot-experimentAC.pdf
Identifiers
  • HAL Id : hal-01579413, version 2
Collections
Citation
Rachit Agarwal, David Gomez, Jorge Lanza, Luis Sanchez, Nikolaos Georgantas, et al.. EnMonitor: Experimentation over Large-scale Semantically Annotated Federated IoT data environment. 2018. ⟨hal-01579413v2⟩
Share
Metrics
Les métriques sont temporairement indisponibles
