Event Handoff Unobservability in WSN - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The open nature of communications in Wireless Sensor Networks (WSNs) makes it easy for an adversary to trace all the communications within the network. If techniques such as encryption may be employed to protect data privacy (i.e. the content of a message), countermeasures to deceive context privacy (e.g. the source of a message) are much less straightforward. In recent years, the research community addressed the problem of context privacy. Some work aimed to hide the position of the collecting node. Other work investigated on hiding the position of an event—sensed by the WSN. However, the solutions proposed for events hiding either: (i) considered only static events; (ii) are not efficient. In this work, we describe open issues that we identified in the current research. In particular, we consider the problem of efficiently hiding mobile events.
978-3-642-19228-9_3_Chapter.pdf (400.67 Ko) Télécharger le fichier
hal-01581330 , version 1 (04-09-2017)
Paternité
Stefano Ortolani, Mauro Conti, Bruno Crispo, Roberto Di Pietro. Event Handoff Unobservability in WSN. 1st Open Research Problems in Network Security (iNetSec), Mar 2010, Sofia, Bulgaria. pp.20-28, ⟨10.1007/978-3-642-19228-9_3⟩. ⟨hal-01581330⟩
35 Consultations
68 Téléchargements
