Analyzing BGP Instances in Maude - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Anduo Wang
  • Fonction : Auteur
  • PersonId : 1015719
Carolyn Talcott
  • Fonction : Auteur
  • PersonId : 1015720
Limin Jia
  • Fonction : Auteur
  • PersonId : 993612
Andre Scedrov
  • Fonction : Auteur
  • PersonId : 1015721
Analyzing Border Gateway Protocol (BGP) instances is a crucial step in the design and implementation of safe BGP systems. Today, the analysis is a manual and tedious process. Researchers study the instances by manually constructing execution sequences, hoping to either identify an oscillation or show that the instance is safe by exhaustively examining all possible sequences. We propose to automate the analysis by using Maude, a tool based on rewriting logic. We have developed a library specifying a generalized path vector protocol, and methods to instantiate the library with customized routing policies. Protocols can be analyzed automatically by Maude, once users provide specifications of the network topology and routing policies. Using our Maude library, protocols or policies can be easily specified and checked for problems. To validate our approach, we performed safety analysis of well-known BGP instances and actual routing configurations.
978-3-642-21461-5_22_Chapter.pdf (229.48 Ko) Télécharger le fichier
hal-01583330 , version 1 (07-09-2017)
Paternité
Anduo Wang, Carolyn Talcott, Limin Jia, Boon Thau Loo, Andre Scedrov. Analyzing BGP Instances in Maude. 13th Conference on Formal Methods for Open Object-Based Distributed Systems (FMOODS) / 31th International Conference on FORmal TEchniques for Networked and Distributed Systems (FORTE), Jun 2011, Reykjavik,, Iceland. pp.334-348, ⟨10.1007/978-3-642-21461-5_22⟩. ⟨hal-01583330⟩
89 Consultations
78 Téléchargements
