A New Leakage-Resilient IBE Scheme in the Relative Leakage Model
We propose the first leakage-resilient Identity-Based Encryption (IBE) scheme with full domain hash structure. Our scheme is leakage-resilient in the relative leakage model and the random oracle model under the decisional bilinear Diffie-Hellman (DBDH) assumption.
