Cooperative Data Access in Multi-cloud Environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Meixing Le
  • Fonction : Auteur
  • PersonId : 1004157
Krishna Kant
  • Fonction : Auteur
  • PersonId : 1004158
Sushil Jajodia
  • Fonction : Auteur
  • PersonId : 978046
In this paper, we discuss the problem of enabling cooperative query execution in a multi-cloud environment where the data is owned and managed by multiple enterprises. We assume that each enterprise defines a set of allow rules to facilitate access to its data, which is assumed to be stored as relational tables. We propose an efficient algorithm using join properties to decide whether a given query will be allowed. We also allow enterprises to explicitly forbid access to certain data via deny rules and propose an efficient algorithm to check for conflicts between allow and deny rules.
978-3-642-22348-8_4_Chapter.pdf (212.67 Ko) Télécharger le fichier
hal-01586583 , version 1 (13-09-2017)
Paternité
Meixing Le, Krishna Kant, Sushil Jajodia. Cooperative Data Access in Multi-cloud Environments. 23th Data and Applications Security (DBSec), Jul 2011, Richmond, VA, United States. pp.14-28, ⟨10.1007/978-3-642-22348-8_4⟩. ⟨hal-01586583⟩
114 Consultations
48 Téléchargements
