Characterizing Latency in Touch and Button-Equipped Interactive Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a low cost method to measure and characterize the end-to-end latency when using a touch system (tap la-tency) or an input device equipped with a physical button. Our method relies on a vibration sensor attached to a finger and a photo-diode to detect the screen response. Both are connected to a micro-controller connected to a host computer using a low-latency USB communication protocol in order to combine software and hardware probes to help determine where the latency comes from. We present the operating principle of our method before investigating the main sources of latency in several systems. We show that most of the latency originates from the display side. Our method can help application designers characterize and troubleshoot latency on a wide range of interactive systems.
casiez17.pdf (2.77 Mo) Télécharger le fichier
Format : Figure, Image
hal-01586803 , version 1 (13-09-2017)
Géry Casiez, Thomas Pietrzak, Damien Marchal, Sébastien Poulmane, Matthieu Falce, et al.. Characterizing Latency in Touch and Button-Equipped Interactive Systems. Proceedings of the ACM Symposium on User Interface Software and Technology (UIST 2017), Oct 2017, Québec, Canada. ⟨10.1145/3126594.3126606⟩. ⟨hal-01586803⟩
370 Consultations
1258 Téléchargements
