1Clemson University (O-110 Martin Hall, Box 340975, Clemson, S.C. 29634 - États-Unis)
Abstract : A method for predicting the performance of disk scheduling algorithms on real machines using only their performance on virtual machines is suggested. The method uses a dynamically loaded kernel intercept probe (iprobe) to adjust low-level virtual device timing to match that of a simple model derived from the real device. An example is provided in which the performance of a newly proposed disk scheduling algorithm is compared with that of standard Linux algorithms. The advantage of the proposed method is that reasonable performance predictions may be made without dedicated measurement platforms and with only relatively limited knowledge of the performance characteristics of the targeted devices.
Type de document :
Communication dans un congrès
Karin Anna Hummel; Helmut Hlavacs; Wilfried Gansterer. Performance Evaluation of Computer and Communication Systems (PERFORM), Oct 2010, Vienna, Austria. Springer, Lecture Notes in Computer Science, LNCS-6821, pp.61-72, 2011, Performance Evaluation of Computer and Communication Systems. Milestones and Future Challenges. 〈10.1007/978-3-642-25575-5_6〉
https://hal.inria.fr/hal-01586905
Contributeur : Hal Ifip
Soumis le : mercredi 13 septembre 2017 - 13:50:04
Dernière modification le : mercredi 8 novembre 2017 - 09:13:20
Document(s) archivé(s) le : jeudi 14 décembre 2017 - 13:34:27
Robert Geist, Zachary Jones, James Westall. Predicting Disk Scheduling Performance with Virtual Machines. Karin Anna Hummel; Helmut Hlavacs; Wilfried Gansterer. Performance Evaluation of Computer and Communication Systems (PERFORM), Oct 2010, Vienna, Austria. Springer, Lecture Notes in Computer Science, LNCS-6821, pp.61-72, 2011, Performance Evaluation of Computer and Communication Systems. Milestones and Future Challenges. 〈10.1007/978-3-642-25575-5_6〉. 〈hal-01586905〉
