HACL * : A Verified Modern Cryptographic Library - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
HACL* is a verified portable C cryptographic library that implements modern cryptographic primitives such as the ChaCha20 and Salsa20 encryption algorithms, Poly1305 and HMAC message authentication, SHA-256 and SHA-512 hash functions, the Curve25519 elliptic curve, and Ed25519 signatures. HACL* is written in the F* programming language and then compiled to readable C code. The F* source code for each cryptographic primitive is verified for memory safety, mitigations against timing side-channels, and functional correctness with respect to a succinct high-level specification of the primitive derived from its published standard. The translation from F* to C preserves these properties and the generated C code can itself be compiled via the CompCert verified C compiler or mainstream compilers like GCC or CLANG. When compiled with GCC on 64-bit platforms, our primitives are as fast as the fastest pure C implementations in OpenSSL and Libsodium, significantly faster than the reference C code in TweetNaCl, and between 1.1x-5.7x slower than the fastest hand-optimized vectorized assembly code in SUPERCOP. HACL* implements the NaCl cryptographic API and can be used as a drop-in replacement for NaCl libraries like Libsodium and TweetNaCl. HACL * provides the cryptographic components for a new mandatory ciphersuite in TLS 1.3 and is being developed as the main cryptographic provider for the miTLS verified implementation. Primitives from HACL* are also being integrated within Mozilla's NSS cryptographic library. Our results show that writing fast, verified, and usable C cryptographic libraries is now practical.
haclstar.pdf (952.27 Ko) Télécharger le fichier
hal-01588421 , version 1 (15-09-2017)
hal-01588421 , version 2 (08-12-2018)
  • HAL Id : hal-01588421 , version 2
Jean-Karim Zinzindohoué, Karthikeyan Bhargavan, Jonathan Protzenko, Benjamin Beurdouche. HACL * : A Verified Modern Cryptographic Library. ACM Conference on Computer and Communications Security (CCS), Oct 2017, Dallas, United States. ⟨hal-01588421v2⟩
Collections
INRIA INRIA2
1767 Consultations
979 Téléchargements
