New interface
Conference papers
LDScript: a Linked Data Script Language
Olivier Corby 1 Catherine Faron Zucker 2, 1 Fabien Gandon 1
1 WIMMICS - Web-Instrumented Man-Machine Interactions, Communities and Semantics
CRISAM - Inria Sophia Antipolis - Méditerranée , Laboratoire I3S - SPARKS - Scalable and Pervasive softwARe and Knowledge Systems
Abstract : In addition to the existing standards dedicated to representation or querying, Semantic Web programmers could really benefit from a dedicated programming language enabling them to directly define functions on RDF terms, RDF graphs or SPARQL results. This is especially the case, for instance, when defining SPARQL extension functions. The ability to capitalize complex SPARQL filter expressions into extension functions or to define and reuse dedicated aggregates are real cases where a dedicated language can support modularity and maintenance of the code. Other families of use cases include the definition of functional properties associated to RDF resources or the definition of procedural attachments as functions assigned to RDFS or OWL classes with the selection of the function to be applied to a resource depending on the type of the resource. To address these needs we define LDScript, a Linked Data script language on top of the SPARQL filter expression language. We provide the formal grammar of the syntax and the Natural Semantics inference rules of the semantics of the language. We also provide a benchmark and perform an evaluation using real test bases from W3C with different implementations and approaches comparing, in particular, script interpretation and Java compilation.
Complete list of metadata
Cited literature [9 references]  Display  Hide  Download
https://hal.inria.fr/hal-01589162
Contributor : Olivier Corby Connect in order to contact the contributor
Submitted on : Monday, September 18, 2017 - 12:02:53 PM
Last modification on : Friday, August 5, 2022 - 3:51:08 AM
File
final.pdf
Identifiers
  • HAL Id : hal-01589162, version 1
Citation
Olivier Corby, Catherine Faron Zucker, Fabien Gandon. LDScript: a Linked Data Script Language. International Semantic Web Conference, Oct 2017, Vienne, Austria. ⟨hal-01589162⟩
Share
Metrics
Record views
728
Files downloads
535
