Abstract : Federated Identity Management is considered a promising approach to facilitate secure resource sharing between collaborating partners. A structured survey has been carried out in order to document the benefits of adopting such systems from a user and business perspective, and also to get an indication on how Integrated Operations in the oil and gas industry can benefit from identity federations. This has resulted in a set of benefit categories grouping existing claims from researchers. The literature indicates that adoption of Federated Identity Management in Integrated Operation seems like a good idea, however, there are several challenges that need to be solved.
https://hal.inria.fr/hal-01590405 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, September 19, 2017 - 3:12:01 PM Last modification on : Tuesday, February 23, 2021 - 7:24:06 PM
Jostein Jensen. Benefits of Federated Identity Management - A Survey from an Integrated Operations Viewpoint. 1st Availability, Reliability and Security (CD-ARES), Aug 2011, Vienna, Austria. pp.1-12, ⟨10.1007/978-3-642-23300-5_1⟩. ⟨hal-01590405⟩
