Evaluating Physical/Virtual Occlusion Management Techniques for Horizontal Displays - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Waqas Javed
  • Fonction : Auteur
  • PersonId : 889223
Kyungtae Kim
  • Fonction : Auteur
  • PersonId : 1017232
Sohaib Ghani
  • Fonction : Auteur
  • PersonId : 1017233
Niklas Elmqvist
  • Fonction : Auteur
  • PersonId : 889224
We evaluate unguided and guided visual search performance for a set of techniques that mitigate occlusion between physical and virtual objects on a tabletop display. The techniques are derived from a general model of hybrid physical/virtual occlusion, and take increasingly drastic measures to make the user aware of, identify, and access hidden objects—but with increasingly space-consuming and disruptive impact on the display. Performance is different depending on the visual display, suggesting a tradeoff between management strength and visual space deformation.
978-3-642-23765-2_27_Chapter.pdf (711.11 Ko) Télécharger le fichier
hal-01591810 , version 1 (22-09-2017)
Paternité
Waqas Javed, Kyungtae Kim, Sohaib Ghani, Niklas Elmqvist. Evaluating Physical/Virtual Occlusion Management Techniques for Horizontal Displays. 13th International Conference on Human-Computer Interaction (INTERACT), Sep 2011, Lisbon, Portugal. pp.391-408, ⟨10.1007/978-3-642-23765-2_27⟩. ⟨hal-01591810⟩
115 Consultations
81 Téléchargements
