Abstract : Retrieving assets inside a secure element is a challenging task.
The most attractive assets are the cryptographic keys stored
into the Non Volatile Memory (NVM) area but also the
algorithms executed. Thus, the confidentiality of binary code
embedded in that device in the Read Only Memory (ROM)
must be protected. Thanks to a previous attack we succeeded
in having access to a dump of NVM. We try here to to take
advantage of the object oriented features of the platform
to provide a means to speed up the reverse engineering of
the dump. The idea here is to reverse engineer an algorithm
without having access to to the code. We have only access
to the data. We use a specifically designed graphic tool to
reason about the data such that we are able to understand
the principle of the algorithm. Then, we are able to bypass
the protection mechanism in order to get access to the binary
code.
