New interface
Conference papers
Access Path Based Source Address Validation in Mobile IPv6
Abstract : Mobile IPv6 runs high risk of being attacked by IP spoofing due to the introduction of mobility and route optimization. In this paper, an authentic IP address validation scheme is proposed to protect mobile nodes in Mobile IPv6 against IP spoofing attack. The mobile nodes’ historical traffic information is leveraged to validate the authenticity of its claimed home address in the scheme. Compared with other authentication schemes, this scheme is much simpler to implement and easier to deploy based on the usage of real data, and does not require additional computational overhead. It also solves the address ownership problem and the unauthenticated binding update issue in Mobile IPv6. Real traces are used to demonstrate the applicability of the scheme in this paper. The experimental results show that only three consecutive historical packet records are required to construct a unique authentication key, which can identify forged home address efficiently.
Document type :
Conference papers
Complete list of metadata
Cited literature [17 references]  Display  Hide  Download
https://hal.inria.fr/hal-01593028
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Monday, September 25, 2017 - 4:34:07 PM
Last modification on : Tuesday, June 1, 2021 - 2:34:10 PM
Long-term archiving on: : Tuesday, December 26, 2017 - 2:26:15 PM
File
978-3-642-24403-2_26_Chapter.p...
Identifiers
Citation
Min Zhu, Ke Xu, Qi Li. Access Path Based Source Address Validation in Mobile IPv6. 8th Network and Parallel Computing (NPC), Oct 2011, Changsha,, China. pp.334-349, ⟨10.1007/978-3-642-24403-2_26⟩. ⟨hal-01593028⟩
Share
Metrics
Record views
56
Files downloads
52
