A perturbation analysis of stochastic matrix Riccati diffusions - Inria - Institut national de recherche en sciences et technologies du numérique
Article Dans Une Revue Annales de l'Institut Henri Poincaré (B) Probabilités et Statistiques Année : 2020
Matrix differential Riccati equations are central in filtering and optimal control theory. The purpose of this article is to develop a perturbation theory for a class of stochastic matrix Riccati diffusions. Diffusions of this type arise, for example, in the analysis of ensemble Kalman-Bucy filters since they describe the flow of certain sample covariance estimates. In this context, the random perturbations come from the fluctuations of a mean field particle interpretation of a class of nonlinear diffusions equipped with an interacting sample covariance matrix functional. The main purpose of this article is to derive non-asymptotic Taylor-type expansions of stochastic matrix Riccati flows with respect to some perturbation parameter. These expansions rely on an original combination of stochastic differential analysis and nonlinear semigroup techniques on matrix spaces. The results here quantify the fluctuation of the stochastic flow around the limiting deterministic Riccati equation, at any order. The convergence of the interacting sample covariance matrices to the deterministic Riccati flow is proven as the number of particles tends to infinity. Also presented are refined moment estimates and sharp bias and variance estimates. These expansions are also used to deduce a functional central limit theorem at the level of the diffusion process in matrix spaces.
hal-01593830 , version 1 (28-09-2017)
Adrian N Bishop, Pierre del Moral, Angèle Niclas. A perturbation analysis of stochastic matrix Riccati diffusions. Annales de l'Institut Henri Poincaré (B) Probabilités et Statistiques, 2020, ⟨10.1214/19-AIHP987⟩. ⟨hal-01593830⟩
154 Consultations
0 Téléchargements
More
