Approximation of a Mathematical Aging Function for Latent Fingerprint Traces Based on First Experiments Using a Chromatic White Light (CWL) Sensor and the Binary Pixel Aging Feature - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The age determination of latent fingerprint traces is a very important challenge for forensic investigations, which has not been solved satisfyingly so far. Based on prior work, we use the novel and very promising aging feature of counting binary pixel for the approximation of a mathematical aging function to be used for the age determination of latent fingerprint traces. We first show the feasibility of this feature in a test set of nine test series (each comprised of a fingerprint sample scanned continuously over four days) using three different optical sensors (CWL) of the same model and varying resolutions (3,5,10μm). We then approximate the aging function for each test series, showing an average error of approximation between 13% and 40% for an optimal approximation. We discuss the prospects and restrictions of such a function for the age determination of latent fingerprint traces and identify future research challenges.
978-3-642-24712-5_5_Chapter.pdf (703.13 Ko) Télécharger le fichier
hal-01596193 , version 1 (27-09-2017)
Paternité
Ronny Merkel, Jana Dittmann, Claus Vielhauer. Approximation of a Mathematical Aging Function for Latent Fingerprint Traces Based on First Experiments Using a Chromatic White Light (CWL) Sensor and the Binary Pixel Aging Feature. 12th Communications and Multimedia Security (CMS), Oct 2011, Ghent, Belgium. pp.59-71, ⟨10.1007/978-3-642-24712-5_5⟩. ⟨hal-01596193⟩
48 Consultations
89 Téléchargements
