A Secure Perceptual Hash Algorithm for Image Content Authentication - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Perceptual hashing is a promising solution to image content authentication. However, conventional image hash algorithms only offer a limited authentication level for the protection of overall content. In this work, we propose an image hash algorithm with block level content protection. It extracts features from DFT coefficients of image blocks. Experiments show that the hash has strong robustness against JPEG compression, scaling, additive white Gaussian noise, and Gaussian smoothing. The hash value is compact, and highly dependent on a key. It has very efficient trade-offs between the false positive rate and the true positive rate.
978-3-642-24712-5_9_Chapter.pdf (524.43 Ko) Télécharger le fichier
hal-01596205 , version 1 (27-09-2017)
Paternité
Li Weng, Bart Preneel. A Secure Perceptual Hash Algorithm for Image Content Authentication. 12th Communications and Multimedia Security (CMS), Oct 2011, Ghent, Belgium. pp.108-121, ⟨10.1007/978-3-642-24712-5_9⟩. ⟨hal-01596205⟩
123 Consultations
365 Téléchargements
