A High-Performance Implementation of Differential Power Analysis on Graphics Cards - Archive ouverte HAL Access content directly
Conference Papers Year : 2011
(1) , (1)
1
We present an implementation for Differential Power Analysis (DPA) that is entirely based on Graphics Processing Units (GPUs). In this paper we make use of advanced techniques offered by the CUDA Framework in order to minimize the runtime. In security testing DPA still plays a major role for the smart card industry and these evaluations require, apart from educationally prepared measurement setups, the analysis of measurements with large amounts of traces and samples, and here time does matter. Most often DPA implementations are tailor-made and adapted to fit certain platforms and hence efficient reference implementations are sparsely seeded. In this work we show that the powerful architecture of graphics cards is well suited to facilitate a DPA implementation, based on the Pearson correlation coefficient, that could serve as a high performant reference, e.g., by analyzing one million traces of 20k samples in less than two minutes.
978-3-642-27257-8_16_Chapter.pdf (191.57 Ko) Télécharger le fichier
Dates and versions
hal-01596313 , version 1 (27-09-2017)
Attribution - CC BY 4.0
Identifiers
Cite
Timo Bartkewitz, Kerstin Lemke-Rust. A High-Performance Implementation of Differential Power Analysis on Graphics Cards. 10th Smart Card Research and Advanced Applications (CARDIS), Sep 2011, Leuven, Belgium. pp.252-265, ⟨10.1007/978-3-642-27257-8_16⟩. ⟨hal-01596313⟩
110 View
1063 Download
Share
