TV Interaction Beyond the Button Press - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Regina Bernhaupt
Michael Pirker
  • Fonction : Auteur
  • PersonId : 1005560
Daniel Schwaiger
  • Fonction : Auteur
  • PersonId : 1018490
In order to enhance users’ interactions with TV user interfaces we developed a prototypical multimodal interaction mechanism that combines tilting, pressing and puffing as input modalities for a novel interface. The interaction mechanism has been evaluated in an exploratory user experience and usability study that used a within subjects design investigating tilt as input mechanism to navigate through the 3D interface compared to tilt combined with pressure and breath input. Results of this first exploratory study indicate that while this uncommon and unfamiliar way to interact with a novel TV user interface impacts usability scores which were below average compared to traditional remote controls, the user interface approach in combination with the new interaction modalities resulted in above-average scores for the user experience dimension of hedonic quality. The findings are subsequently reflected and implications of using alternative input modalities for TV user interfaces are discussed.
346942_1_En_31_Chapter.pdf (223.41 Ko) Télécharger le fichier
hal-01599878 , version 1 (02-10-2017)
Paternité
Regina Bernhaupt, Antoine Desnos, Michael Pirker, Daniel Schwaiger. TV Interaction Beyond the Button Press. 15th Human-Computer Interaction (INTERACT 2015), Sep 2015, Bamberg, Germany. pp.412-419, ⟨10.1007/978-3-319-22668-2_31⟩. ⟨hal-01599878⟩
277 Consultations
341 Téléchargements
