Thinking Like Disney: Supporting the Disney Method Using Ambient Feedback Based on Group Performance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The Disney method is a collaborative creativity technique that uses three roles - dreamer, realist and critic - to facilitate the consideration of different perspectives on a topic. Especially for novices it is important to obtain guidance in applying this method. One way is providing groups with a trained moderator. However, feedback about the group’s behavior might interrupt the flow of the idea finding process. We built and evaluated a system that provides ambient feedback to a group about the distribution of their statements among the three roles. Our preliminary field study indicates that groups supported by the system contribute more and roles are used in a more balanced way while the visualization does not disrupt the group work.
346946_1_En_42_Chapter.pdf (237.09 Ko) Télécharger le fichier
hal-01609410 , version 1 (03-10-2017)
Paternité
Sarah Tausch, Fabius Steinberger, Heinrich Hussmann. Thinking Like Disney: Supporting the Disney Method Using Ambient Feedback Based on Group Performance. 15th Human-Computer Interaction (INTERACT), Sep 2015, Bamberg, Germany. pp.614-621, ⟨10.1007/978-3-319-22698-9_42⟩. ⟨hal-01609410⟩
129 Consultations
423 Téléchargements
