Abstract : Thanks to its low energy consumption and very long range (up
to 50 km in free-space), ultra-narrow-band transmission (UNB) represents a
promising alternative to classical technologies used in cellular networks to serve
low-throughput wireless sensor networks (WSNs) and the Internet of things
(IoT). In UNB, nodes access to the medium by selecting their frequency in
a random and continuous way. This randomness leads to new behavior in
the interference which has not been theoretically analyzed, when considering
the pathloss of nodes randomly deployed around the receiver. In this paper, in
order to quantify the system performance, we derive and exploit two theoretical
expressions of the outage probability in a UNB based IoT network, accounting
for both interference due to the spectral randomness and path loss due to the
propagation (with and without Rayleigh fading). This enables us to estimate
the network capacity as a function of the path-loss exponent, by determining
the maximum number of simultaneous supported nodes. We highlight that the
bandwidth should be chosen based on the propagation channel properties.
