Comparing Fatigue When Using Large Horizontal and Vertical Multi-touch Interaction Displays - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Shiroq Al-Megren
  • Fonction : Auteur
  • PersonId : 1020135
Ahmed Kharrufa
  • Fonction : Auteur
  • PersonId : 1018477
Jonathan Hook
  • Fonction : Auteur
  • PersonId : 1020136
Amey Holden
  • Fonction : Auteur
  • PersonId : 1020137
Selina Sutton
  • Fonction : Auteur
  • PersonId : 1020138
Patrick Olivier
  • Fonction : Auteur
  • PersonId : 1005559
We report on a user study that compared muscle fatigue experienced when using a large multi-touch display in horizontal and vertical configurations over a one-hour period. Muscle fatigue is recognized as the reduction in a muscle’s capacity to generate force or power output and was measured objectively and subjectively before and after a puzzle-solving task. While subjective measures showed a significant level of overall arm muscle fatigue after the task for both configurations, objective measures showed a significant level of muscle fatigue on the middle deltoids and the non-dominant extensor digitorum for the vertical configuration only. We discuss the design implications of these findings and suggest relevant future areas of investigation.
346948_1_En_13_Chapter.pdf (347.55 Ko) Télécharger le fichier
hal-01610843 , version 1 (05-10-2017)
Paternité
Shiroq Al-Megren, Ahmed Kharrufa, Jonathan Hook, Amey Holden, Selina Sutton, et al.. Comparing Fatigue When Using Large Horizontal and Vertical Multi-touch Interaction Displays. 15th Human-Computer Interaction (INTERACT), Sep 2015, Bamberg, Germany. pp.156-164, ⟨10.1007/978-3-319-22723-8_13⟩. ⟨hal-01610843⟩
61 Consultations
106 Téléchargements
