Applying “Out of Body” Vibrotactile Illusion to Two-Finger Interaction for Perception of Object Dynamics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jaedong Lee
  • Fonction : Auteur
  • PersonId : 1005031
Youngsun Kim
  • Fonction : Auteur
  • PersonId : 1020063
Gerard J. Kim
  • Fonction : Auteur
  • PersonId : 1005033
Vibrotactile feedback is an effective and economical approach for enriching interactive feedback. However, its effects are mostly limited to providing supplementary alarms or conveying the sense of simple object presence or contact. We propose to apply the “out of body” tactile illusion for selecting and manipulating a virtual moving object while also being able to feel its dynamics using two fingers. We assessed the user experience (focusing on the perception of the dynamics of the selected object) of the proposed method by comparing it to the conventional contact-based method. Our results indicate that users were able to perceive the dynamic feedback, and preferred it over the conventional method.
346948_1_En_49_Chapter.pdf (268 Ko) Télécharger le fichier
hal-01610851 , version 1 (05-10-2017)
Paternité
Jaedong Lee, Youngsun Kim, Gerard J. Kim. Applying “Out of Body” Vibrotactile Illusion to Two-Finger Interaction for Perception of Object Dynamics. 15th Human-Computer Interaction (INTERACT), Sep 2015, Bamberg, Germany. pp.506-509, ⟨10.1007/978-3-319-22723-8_49⟩. ⟨hal-01610851⟩
57 Consultations
101 Téléchargements
