Transforming face-to-face identity proofing into anonymous digital identity using the Bitcoin blockchain - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The most fundamental purpose of blockchain technology is to enable persistent, consistent, distributed storage of information. Increasingly common are authentication systems that leverage this property to allow users to carry their personal data on a device while a hash of this data is signed by a trusted authority and then put on a blockchain to be compared against. For instance, in 2015, MIT introduced a schema for the publication of their academic certificates based on this principle. In this work, we propose a way for users to obtain assured identities based on face-to-face proofing that can then be validated against a record on a blockchain. Moreover, in order to provide anonymity, instead of storing a hash, we make use of a scheme of Brands to store a commitment against which one can perform zero-knowledge proofs of identity. We also enforce the confidentiality of the underlying data by letting users control a secret of their own. We show how our schema can be implemented on Bitcoin's blockchain and how to save bandwidth by grouping commitments using Merkle trees to minimize the number of Bitcoin transactions that need to be sent. Finally, we describe a system in which users can gain access to services thanks to the identity records of our proposal.
accg-pst-finalversion.pdf (192.05 Ko) Télécharger le fichier
hal-01611297 , version 1 (06-10-2017)
Daniel Augot, Hervé Chabanne, Olivier Clémot, William George. Transforming face-to-face identity proofing into anonymous digital identity using the Bitcoin blockchain. PST 2017 - International Conference on Privacy, Security and Trust, Aug 2017, Calgary, Canada. pp.1-10. ⟨hal-01611297⟩
391 Consultations
296 Téléchargements
