Conference papers
Research of Fractal Compression Algorithm Taking Details in Consideration in Agriculture Plant Disease and Insect Pests Image
Abstract : Agriculture plant disease and insect pests is varied and tremendously harmful, so experts are needed to diagnose. But experts can’t have the energy and time to the field for the majority of farmers to guide, they can only get the image through remote. However, agriculture plant disease and insect pests image is rich in detail, while transmission bandwidth and storage is limited, it is necessary to compress image to make sure of image quality. This paper proposes an improved method based on Jacquin theory to reduce coding time. Encoded sub block is classified into detailed block and non-detailed block, so we can reduce the encoding time. Experimental results show that, for the agriculture plant disease and insect pests image which is rich in detail, the number of encoded blocks reduces to 31.45 % and the encoding time reduces to 32.9 % of the original one.
Document type :
Conference papers
Complete list of metadata
Cited literature [14 references]  Display  Hide  Download
https://hal.inria.fr/hal-01614216
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Tuesday, October 10, 2017 - 3:43:43 PM
Last modification on : Tuesday, October 10, 2017 - 3:53:31 PM
Long-term archiving on: : Thursday, January 11, 2018 - 2:24:00 PM
File
434298_1_En_50_Chapter.pdf
Identifiers
Citation
Qiao Deng, Chunhong Liu, Liting Fu. Research of Fractal Compression Algorithm Taking Details in Consideration in Agriculture Plant Disease and Insect Pests Image. 9th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Sep 2015, Beijing, China. pp.496-504, ⟨10.1007/978-3-319-48354-2_50⟩. ⟨hal-01614216⟩
Share
Metrics
Record views
38
Files downloads
67
