Abstract :
A rigorous evaluation of an artifact is one of the fundamental aspects to be considered in Design Science Research projects. This evaluation part becomes even more difficult when a large variety of artifacts must be designed for a project. This can be a challenge for the field of Collaborative Networks, which involves knowledge from several scientific disciplines. Case studies are one of the evaluation methods in Design Science Research that are used for an ex-post evaluation of artifacts. However, we argue that this method can also be used for the ex-ante evaluation, mainly when multidisciplinary research is being carried out. Therefore, the main objective of this paper is to present and discuss a multidisciplinary project of Collaborative Networks using case studies before and after the design of the artifacts. On top of the Design Science Research guidelines, this research is supported by knowledge from Business and Management Studies on how to effectively design and perform Case Study Research for artifact evaluation.
https://hal.inria.fr/hal-01614622 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Wednesday, October 11, 2017 - 10:41:55 AM Last modification on : Friday, April 22, 2022 - 11:42:05 AM Long-term archiving on: : Friday, January 12, 2018 - 1:36:26 PM
Eric Costa, António Lucas Soares, Jorge Sousa. Situating Case Studies Within the Design Science Research Paradigm: An Instantiation for Collaborative Networks. 17th Working Conference on Virtual Enterprises (PRO-VE), Oct 2016, Porto, Portugal. pp.531-544, ⟨10.1007/978-3-319-45390-3_45⟩. ⟨hal-01614622⟩
