Abstract : The aim of this research is to analyze the support policies and the collective efficiency in a furniture cluster in the South region of Brazil, subject of scarce studies despite its importance. Using quantitative methodology we made a survey with 20 companies of this furniture cluster. The results indicated that support policies and collective efficiency were statistically correlated. The contribution of this paper to the literature is to reinforce that the findings that support policies are a way to improve collective efficiency, and so provide competitiveness to all the companies that belong to the cluster. This research was made on a temporal transversal cut, a characteristic of studies in networks, so the result does not allow generalizations.
https://hal.inria.fr/hal-01615714 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Thursday, October 12, 2017 - 4:39:30 PM Last modification on : Thursday, March 5, 2020 - 4:46:15 PM
Elizangela Lima, Walter Satyro, Jose Sacomano, Esdras Barboza, Renato Telles. Support Policies and Collective Efficiency in a Furniture Cluster. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2016, Iguassu Falls, Brazil. pp.272-279, ⟨10.1007/978-3-319-51133-7_33⟩. ⟨hal-01615714⟩
