Theoretical Framework of Performance Indicators with BSC for the Private Higher Education Institution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Analyzing the performance of an organization requires the use of indicators. In recent decades, an indicator in particular has highlighted, the balanced scorecard (BSC). Therefore, a type of company specific, private higher education institutions (HEI’s), has received little attention in research in this area, especially in how is the process of applying these indicators. Thus, this study aims to understand how is the balanced score card application process on a private higher education institution. For this, this study drew on research built by authors who discuss this application, in order to develop a theoretical framework, demonstrating how this process occurs. So, theoretical contributions were generated by this study with the analysis of other theoretical contributions of more extensive research, in which they individually could not handle to fill this theoretical gap in the literature.
434863_1_En_54_Chapter.pdf (391.65 Ko) Télécharger le fichier
hal-01615739 , version 1 (12-10-2017)
Paternité
Átila De Melo Lira, Irenilza Näas. Theoretical Framework of Performance Indicators with BSC for the Private Higher Education Institution. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2016, Iguassu Falls, Brazil. pp.452-458, ⟨10.1007/978-3-319-51133-7_54⟩. ⟨hal-01615739⟩
342 Consultations
102 Téléchargements
