Industrial IoT Gateway with Machine Learning for Smart Manufacturing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Tomáš Lojka
  • Fonction : Auteur
  • PersonId : 991403
Martin Miškuf
  • Fonction : Auteur
  • PersonId : 1020820
Iveta Zolotová
  • Fonction : Auteur
  • PersonId : 991404
Working together is important aspect of future industry. Therefore, technologies like Internet of Things (IoT), cloud computing, SOA give rise to another industrial revolution. We propose here a concept definition, which focuses on data acquisition, integration and predictive control in the industry. The concept consists of industrial IoT gateway, cloud services and machine learning services. We used machine learning to verify our data acquisition solution and we implemented prediction control as a cloud service. Finally, proposed solution will exceed boundaries inside ICS (Information and Control System), improve flexibility, interoperability and test plant prediction control in smart manufacturing.
434863_1_En_89_Chapter.pdf (468.66 Ko) Télécharger le fichier
hal-01615742 , version 1 (12-10-2017)
Paternité
Tomáš Lojka, Martin Miškuf, Iveta Zolotová. Industrial IoT Gateway with Machine Learning for Smart Manufacturing. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2016, Iguassu Falls, Brazil. pp.759-766, ⟨10.1007/978-3-319-51133-7_89⟩. ⟨hal-01615742⟩
383 Consultations
328 Téléchargements
