ALOC: Attribute Level of Confidence for a User-Centric Attribute Assurance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2016
Salameh Abu Rmeileh
  • Fonction : Auteur
  • PersonId : 1021221
Esther Palomar
  • Fonction : Auteur
  • PersonId : 1021222
Hanifa Shah
  • Fonction : Auteur
  • PersonId : 1021223
The proliferation of online services leads to an increasing number of different digital identities that each user has. In order to enforce access control policies, service providers need assurance that the information associated with users’ identities, either received by the user or a federation partner, are correct and trustworthy. Current identity assurance frameworks assess the trustworthiness of identity providers but do not define trust on the user attribute level of granularity. In this paper, we consider the user attribute as a dynamic structure that extends the foundation of attribute authenticity and trustworthiness by introducing the attribute level of confidence (ALOC). Basically, the ALOC encompasses additional information on attributes’ lifecycle and issuing mechanisms. We present the architecture design and demonstrate its components. This paper concludes discussing future research directions.
428330_1_En_16_Chapter.pdf (266.76 Ko) Télécharger le fichier
hal-01619739 , version 1 (19-10-2017)
Paternité
Salameh Abu Rmeileh, Esther Palomar, Hanifa Shah. ALOC: Attribute Level of Confidence for a User-Centric Attribute Assurance. David Aspinall; Jan Camenisch; Marit Hansen; Simone Fischer-Hübner; Charles Raab. Privacy and Identity Management. Time for a Revolution? : 10th IFIP WG 9.2, 9.5, 9.6/11.7, 11.4, 11.6/SIG 9.2.2 International Summer School, Edinburgh, UK, August 16-21, 2015, Revised Selected Papers, AICT-476, Springer International Publishing, pp.239-252, 2016, IFIP Advances in Information and Communication Technology, 978-3-319-41762-2. ⟨10.1007/978-3-319-41763-9_16⟩. ⟨hal-01619739⟩
122 Consultations
67 Téléchargements
