An Ontological Approach for Organizing a Knowledge Base to Share and Reuse Business Workflow Templates - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Business process models have been used in a lot of enterprise applications. Along with their popularity, the problem of how to create them correctly in terms of semantics and syntax while effectively promoting the reuse of suitable parts of existing models is increasingly interest. This paper describes how to organize a knowledge base to facilitate the shareability and reusability of business workflow templates. We first introduce a repository consisting of business workflow templates which are well-checked at the syntactic and semantic level. An organizational mechanism for control flow-based business workflow templates is therefore provided to ensure an effective search of templates. We then propose a process for developing workflow templates. Thereby for each use case, users can select and modify suitable workflow templates from the knowledge base.
NguyenThiHoaHue_43.pdf (953.27 Ko) Télécharger le fichier
hal-01625663 , version 1 (28-10-2017)
Thi Hoa Hue Nguyen, Tuan Phan-Hong, Nhan Le Thanh. An Ontological Approach for Organizing a Knowledge Base to Share and Reuse Business Workflow Templates. ICIST 2017- Seventh International Conference on Information Science and Technology, Apr 2017, Danang, Vietnam. pp.271 - 277, ⟨10.1109/ICIST.2017.7926769⟩. ⟨hal-01625663⟩
158 Consultations
250 Téléchargements
