Secure Composition of PKIs with Public Key Protocols
We use symbolic formal models to study the composition of public key-based protocols with public key infras-tructures (PKIs). We put forth a minimal set of requirements which a PKI should satisfy and then identify several reasons why composition may fail. Our main results are positive and offer various trade-offs which align the guarantees provided by the PKI with those required by the analysis of protocol with which they are composed. We consider both the case of ideally distributed keys but also the case of more realistic PKIs. Our theorems are broadly applicable. Protocols are not limited to specific primitives and compositionality asks only for minimal requirements on shared ones. Secure composition holds with respect to arbitrary trace properties that can be specified within a reasonably powerful logic. For instance, secrecy and various forms of authentication can be expressed in this logic. Finally, our results alleviate the common yet demanding assumption that protocols are fully tagged.
Cryptographie et sécurité [cs.CR]
