A Survey of Security Analysis in Federated Identity Management - Archive ouverte HAL Access content directly
Book Sections Year : 2016
(1) , (1)
1
Thomas Gross
  • Function : Author
  • PersonId : 1022148
We conduct a systematic survey of security analysis in Federated Identity Management (FIM). We use a categorisation system based off the Malicious and Accidental Fault Tolerance framework (MAFTIA) to categorise security incidents in FIM. When security incidents are categorised, we can paint a picture of the landscape of problems that have been studied in FIM. We outline the security incidents that are happening across FIM protocols and present solutions to those security incidents as proposed by others.
447020_1_En_16_Chapter.pdf (209.34 Ko) Télécharger le fichier
Dates and versions
hal-01629158 , version 1 (06-11-2017)
Attribution - CC BY 4.0
Identifiers
Cite
Sean Simpson, Thomas Gross. A Survey of Security Analysis in Federated Identity Management. Anja Lehmann; Diane Whitehouse; Simone Fischer-Hübner; Lothar Fritsch; Charles Raab. Privacy and Identity Management. Facing up to Next Steps : 11th IFIP WG 9.2, 9.5, 9.6/11.7, 11.4, 11.6/SIG 9.2.2 International Summer School, Karlstad, Sweden, August 21-26, 2016, Revised Selected Papers, AICT-498, Springer International Publishing, pp.231-247, 2016, IFIP Advances in Information and Communication Technology, 978-3-319-55782-3. ⟨10.1007/978-3-319-55783-0_16⟩. ⟨hal-01629158⟩
256 View
154 Download
Share
