Large scale flows under location uncertainty: a consistent stochastic framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Quarterly Journal of the Royal Meteorological Society Année : 2018
Using a classical example, the Lorenz-63 model, an original stochastic framework is applied to represent large-scale geophysical flow dynamics. Rigorously derived from a reformulated material derivative, the proposed framework encompasses several meaningful mechanisms to model geophysical flows. The slightly compressible setup , as treated in the Boussinesq approximation, brings up a stochastic transport equation for the density and other related thermo-dynamical variables. Coupled to the momentum equation through a forcing term, a resulting stochastic Lorenz-63 model is consistently derived. Based on such a reformulated model, the pertinence of this large-scale stochastic approach is demonstrated over classical eddy-viscosity based large-scale representations.
Lorenz-V2.pdf (3.54 Mo) Télécharger le fichier
hal-01629898 , version 1 (06-11-2017)
Bertrand Chapron, Pierre Dérian, Etienne Mémin, Valentin Resseguier. Large scale flows under location uncertainty: a consistent stochastic framework. Quarterly Journal of the Royal Meteorological Society, 2018, 144 (710), pp.251-260. ⟨10.1002/qj.3198⟩. ⟨hal-01629898⟩
715 Consultations
354 Téléchargements
