A Distributed Monitoring Strategy for Detecting Version Number Attacks in RPL-Based Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Network and Service Management Année : 2017
Anthéa Mayzaud
Rémi Badonnel
  • Fonction : Auteur
  • PersonId : 947216
Isabelle Chrisment
The Internet of Things is characterized by the large-scale deployment of low power and lossy networks (LLN), interconnecting pervasive objects. The routing protocol for LLN (RPL) protocol has been standardized by IETF to enable a lightweight and robust routing in these constrained networks. A versioning mechanism is incorporated into RPL in order to maintain an optimized topology. However, an attacker can exploit this mechanism to significantly damage the network and reduce its lifetime. After analyzing and comparing existing work, we propose in this paper a monitoring strategy with dedicated algorithms for detecting such attacks and identifying the involved malicious nodes. The performance of this solution is evaluated through extensive experiments, and its scalability is quantified with the support of a monitoring node placement optimization method.
Fichier non déposé
hal-01630840 , version 1 (08-11-2017)
Anthéa Mayzaud, Rémi Badonnel, Isabelle Chrisment. A Distributed Monitoring Strategy for Detecting Version Number Attacks in RPL-Based Networks. IEEE Transactions on Network and Service Management, 2017, 14 (2), pp.472 - 486. ⟨10.1109/TNSM.2017.2705290⟩. ⟨hal-01630840⟩
131 Consultations
0 Téléchargements
