Single-channel audio source separation with NMF: divergences, constraints and algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2018
Spectral decomposition by nonnegative matrix factorisation (NMF) has become state-of-the-art practice in many audio signal processing tasks, such as source separation, enhancement or transcription. This chapter reviews the fundamentals of NMF-based audio decomposition, in unsupervised and informed settings. We formulate NMF as an optimisation problem and discuss the choice of the measure of fit. We present the standard majorisation-minimisation strategy to address optimisation for NMF with common beta-divergence, a family of measures of fit that takes the quadratic cost, the generalised Kullback-Leibler divergence and the Itakura-Saito divergence as special cases. We discuss the reconstruction of time-domain components from the spectral factorisation and present common variants of NMF-based spectral decomposition: supervised and informed settings, regularised versions, temporal models.
fevotte_book18.pdf (1.59 Mo) Télécharger le fichier
hal-01631185 , version 1 (08-11-2017)
  • HAL Id : hal-01631185 , version 1
Cédric Févotte, Emmanuel Vincent, Alexey Ozerov. Single-channel audio source separation with NMF: divergences, constraints and algorithms. Audio Source Separation, Springer, 2018. ⟨hal-01631185⟩
608 Consultations
4409 Téléchargements
