Reasoning About Firewall Policies Through Refinement and Composition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ultan Neville
  • Fonction : Auteur
  • PersonId : 1022669
Simon N. Foley
  • Fonction : Auteur
  • PersonId : 1001643
An algebra is proposed for constructing and reasoning about anomaly-free firewall policies. Based on the notion of refinement as safe replacement, the algebra provides operators for sequential composition, union and intersection of policies. The algebra is used to specify and reason about iptables firewall policy configurations. A prototype policy management toolkit has been implemented.
428203_1_En_19_Chapter.pdf (337.84 Ko) Télécharger le fichier
hal-01633676 , version 1 (13-11-2017)
Paternité
Ultan Neville, Simon N. Foley. Reasoning About Firewall Policies Through Refinement and Composition. 30th IFIP Annual Conference on Data and Applications Security and Privacy (DBSec), Jul 2016, Trento, Italy. pp.268-284, ⟨10.1007/978-3-319-41483-6_19⟩. ⟨hal-01633676⟩
56 Consultations
183 Téléchargements
