Evaluation of NoC on Multi-FPGA Interconnection Using GTX Transceiver - Archive ouverte HAL Access content directly
Conference Papers Year :
(1) , (1) , (1)
1
Multi-FPGA platforms are very popular today for pre-silicon verification of complex designs due to their low cost and high speed. The idea is to divide these systems into smaller subsystems and implement each one on a separate chip. The challenge is that the number of IOs available on FPGA remains constant despite the technological evolution. This problem is resolved by multiplexing several cut-signals using the time division multiplexing scheduling mechanism. This structure has a strong effect on the speed of transmission between FPGAs. However, an inter-FPGA bottleneck appears. In this paper, we focus on evaluating the Network-on-Chip on multi-FPGA using the high speed serial transceiver GTX block. In order to speed up the transmission between FPGAs, GTX Transceiver is used to provide a high bandwidth while using fewer pins compared to existing approaches based on ordinary FPGA IOs pins. Depending on the available multi-gigabit transceiver, the bandwidth per connection is between 3.125 and 28 Gb/s which allows for large amounts of data to be moved quickly between multiple FPGAs. In our evaluation, a VC707 platform based on the Virtex-7 device is used. The simulation results show that the proposed architecture provides low area consumption and latencies under different traffic patterns.
Dorai17ICECS.pdf (992.93 Ko) Télécharger le fichier
Dates and versions
hal-01633785 , version 1 (13-11-2017)
Identifiers
  • HAL Id : hal-01633785 , version 1
Cite
Atef Dorai, Olivier Sentieys, Héléne Dubois. Evaluation of NoC on Multi-FPGA Interconnection Using GTX Transceiver. 24th IEEE International Conference on Electronics, Circuits and Systems (ICECS), Dec 2017, Batumi, Georgia. ⟨hal-01633785⟩
549 View
392 Download
Share
