Proof theory for indexed nested sequents - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Fitting's indexed nested sequents can be used to give deduc-tive systems to modal logics which cannot be captured by pure nested sequents. In this paper we show how the standard cut-elimination procedure for nested sequents can be extended to indexed nested sequents, and we discuss how indexed nested sequents can be used for intuitionistic modal logics.
Tableaux17.pdf (406.43 Ko) Télécharger le fichier
hal-01635935 , version 1 (15-11-2017)
  • HAL Id : hal-01635935 , version 1
Sonia Marin, Lutz Strassburger. Proof theory for indexed nested sequents. TABLEAUX 2017 - Automated Reasoning with Analytic Tableaux and Related Methods, Sep 2017, Brasilia, Brazil. pp.81-97. ⟨hal-01635935⟩
105 Consultations
156 Téléchargements
