vmBBThrPred: A Black-Box Throughput Predictor for Virtual Machines in Cloud Environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Javid Taheri
  • Fonction : Auteur
  • PersonId : 1023162
Albert Y. Zomaya
  • Fonction : Auteur
  • PersonId : 1011333
Andreas Kassler
  • Fonction : Auteur
  • PersonId : 1023163
In today’s ever computerized society, Cloud Data Centers are packed with numerous online services to promptly respond to users and provide services on demand. In such complex environments, guaranteeing throughput of Virtual Machines (VMs) is crucial to minimize performance degradation for all applications. vmBBThrPred, our novel approach in this work, is an application-oblivious approach to predict performance of virtualized applications based on only basic Hypervisor level metrics. vmBBThrPred is different from other approaches in the literature that usually either inject monitoring codes to VMs or use peripheral devices to directly report their actual throughput. vmBBThrPred, instead, uses sensitivity values of VMs to cloud resources (CPU, Mem, and Disk) to predict their throughput under various working scenarios (free or under contention); sensitivity values are calculated by vmBBProfiler that also uses only Hypervisor level metrics. We used a variety of resource intensive benchmarks to gauge efficiency of our approach in our VMware-vSphere based private cloud. Results proved accuracy of 95 % (on average) for predicting throughput of 12 benchmarks over 1200 h of operation.
416679_1_En_2_Chapter.pdf (822.77 Ko) Télécharger le fichier
hal-01638596 , version 1 (20-11-2017)
Paternité
Javid Taheri, Albert Y. Zomaya, Andreas Kassler. vmBBThrPred: A Black-Box Throughput Predictor for Virtual Machines in Cloud Environments. 5th European Conference on Service-Oriented and Cloud Computing (ESOCC), Sep 2016, Vienna, Austria. pp.18-33, ⟨10.1007/978-3-319-44482-6_2⟩. ⟨hal-01638596⟩
599 Consultations
108 Téléchargements
