Searching Critical Values for Floating-Point Programs - Archive ouverte HAL Access content directly
Conference Papers Year : 2016
(1) , (1) , (1)
1
Programs with floating-point computations are often derived from mathematical models or designed with the semantics of the real numbers in mind. However, for a given input, the computed path with floating-point numbers may significantly differ from the path corresponding to the same computation with real numbers. As a consequence, developers do not know whether the program can actually produce very unexpected outputs. We introduce here a new constraint-based approach that searches for test cases in the part of the over-approximation where errors due to floating-point arithmetic could lead to unexpected decisions.
419911_1_En_13_Chapter.pdf (281.97 Ko) Télécharger le fichier
Dates and versions
hal-01643710 , version 1 (21-11-2017)
Attribution - CC BY 4.0
Identifiers
Cite
Hélène Collavizza, Claude Michel, Michel Rueher. Searching Critical Values for Floating-Point Programs. 28th IFIP International Conference on Testing Software and Systems (ICTSS), Oct 2016, Graz, Austria. pp.209-217, ⟨10.1007/978-3-319-47443-4_13⟩. ⟨hal-01643710⟩
56 View
94 Download
Share
