Efficient second-order online kernel learning with adaptive embedding
Online kernel learning (OKL) is a flexible framework to approach prediction problems, since the large approximation space provided by reproducing kernel Hilbert spaces can contain an accurate function for the problem. Nonetheless, optimizing over this space is computationally expensive. Not only first order methods accumulate O( sqrt T ) more loss than the optimal function, but the curse of kernelization results in a O(t) per step complexity. Second-order methods get closer to the optimum much faster, suffering only O( log(T)) regret, but second-order updates are even more expensive, with a O(t 2) per-step cost. Existing approximate OKL methods try to reduce this complexity either by limiting the Support Vectors (SV) introduced in the predictor, or by avoiding the kernelization process altogether using embedding. Nonetheless, as long as the size of the approximation space or the number of SV does not grow over time, an adversary can always exploit the approximation process. In this paper, we propose PROS-N-KONS, a method that combines Nystrom sketching to project the input point in a small, accurate embedded space, and performs efficient second-order updates in this space. The embedded space is continuously updated to guarantee that the embedding remains accurate, and we show that the per-step cost only grows with the effective dimension of the problem and not with T . Moreover, the second-order updated allows us to achieve the logarithmic regret. We empirically compare our algorithm on recent large-scales benchmarks and show it performs favorably.
