hwloc: A Generic Framework for Managing Hardware Affinities in HPC Applications, 2010 18th Euromicro Conference on Parallel, Distributed and Network-based Processing, pp.180-186, 2010. ,
DOI : 10.1109/PDP.2010.67
URL : https://hal.archives-ouvertes.fr/inria-00429889
Process Placement in Multicore Clusters:Algorithmic Issues and Practical Techniques, IEEE Transactions on Parallel and Distributed Systems, vol.25, issue.4, pp.993-1002 ,
DOI : 10.1109/TPDS.2013.104
URL : https://hal.archives-ouvertes.fr/hal-00803548
Memory and Thread Placement Effects as a Function of Cache Usage: A Study of the Gaussian Chemistry Code on the SunFire X4600 M2, 2008 International Symposium on Parallel Architectures, Algorithms, and Networks (i-span 2008), pp.31-36, 2008. ,
DOI : 10.1109/I-SPAN.2008.13
Multi-GPU Programming, GPU Technology Conference, 2012. ,
StarPU: A Unified Platform for Task Scheduling on Heterogeneous Multicore Architectures Concurrency and Computation: Practice and Experience, Special Issue: Euro-Par, pp.187-198, 2009. ,
DOI : 10.1007/978-3-642-03869-3_80
URL : http://hal.inria.fr/docs/00/38/43/63/PDF/AugThiNamWac09Europar.pdf
On the Overhead of Topology Discovery for Locality-Aware Scheduling in HPC, 2017 25th Euromicro International Conference on Parallel, Distributed and Network-based Processing (PDP), 2017. ,
DOI : 10.1109/PDP.2017.35
URL : https://hal.archives-ouvertes.fr/hal-01402755
Exascale Hardware Architectures Working Group, NNSA Workshop: From Petascale to Exascale: R&D Challenges for HPC Simulation Environments, 2011. ,
DOI : 10.2172/1022133
URL : https://digital.library.unt.edu/ark:/67531/metadc837022/m2/1/high_res_d/1022133.pdf
Address space randomization in 2.6, 2005. ,
PMIx, Proceedings of the 24th European MPI Users' Group Meeting on , EuroMPI '17, pp.1-14, 2017. ,
DOI : 10.1145/2726935.2726944
Managing the topology of heterogeneous cluster nodes with hardware locality (hwloc), 2014 International Conference on High Performance Computing & Simulation (HPCS), pp.74-81, 2014. ,
DOI : 10.1109/HPCSim.2014.6903671
URL : https://hal.archives-ouvertes.fr/hal-00985096
Hybrid MPI/OpenMP Parallel Programming on Clusters of Multi-Core SMP Nodes, 2009 17th Euromicro International Conference on Parallel, Distributed and Network-based Processing, pp.427-436, 2009. ,
DOI : 10.1109/PDP.2009.43
The virtualization model of parallel programming : Runtime optimizations and the state of art, LACSI 2002, 2002. ,
Scalable High Performance Message Passing over InfiniBand for Open MPI, Proceedings of 3rd KiCC Workshop 2007. RWTH Aachen, 2007. ,
MPI and communication---High-performance and scalable MPI over InfiniBand with reduced memory usage, Proceedings of the 2006 ACM/IEEE conference on Supercomputing , SC '06, 2006. ,
DOI : 10.1145/1188455.1188565
Scalable MPI design over InfiniBand using eXtended Reliable Connection, 2008 IEEE International Conference on Cluster Computing, pp.203-212, 2008. ,
DOI : 10.1109/CLUSTR.2008.4663773
URL : http://nowlab.cse.ohio-state.edu/publications/conf-papers/2008/koop-cluster08.pdf
MPC-MPI: An MPI Implementation Reducing the Overall Memory Consumption, PVM/MPI, vol.9, pp.94-103, 2009. ,
DOI : 10.1007/3-540-27039-6_19
Partially Separated Page Tables for Efficient Operating System Assisted Hierarchical Memory Management on Heterogeneous Architectures, 2013 13th IEEE/ACM International Symposium on Cluster, Cloud, and Grid Computing, pp.360-368, 2013. ,
DOI : 10.1109/CCGrid.2013.59
Memory Compression Techniques for Network Address Management in MPI, 2017 IEEE International Parallel and Distributed Processing Symposium (IPDPS), pp.1008-1017, 2017. ,
DOI : 10.1109/IPDPS.2017.18
An Efficient and Transparent Thread Migration Scheme in the PM2 Runtime System Available: https, Proceedings of the 11 IPPS/SPDP'99 Workshops Held in Conjunction with the 13th International Parallel Processing Symposium and 10th Symposium on Parallel and Distributed Processing, pp.496-510, 1999. ,
Available: https://doi, pp.306-322, 2004. ,
MPC: A Unified Parallel Runtime for Clusters of NUMA Machines, Proceedings of the 14th International Euro-Par Conference on Parallel Processing, ser. Euro-Par '08, pp.78-88, 2008. ,
DOI : 10.1007/978-3-540-85451-7_9
