The Asymptotic of Transmission Eigenvalues for a Domain with a Thin Coating - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Applied Mathematics Année : 2018
We consider the transmission eigenvalue problem for a medium surrounded by a thin layer of inhomogeneous material with different refractive index. We derive explicit asymptotic expansion for the transmission eigenvalues with respect to the thickness of the thin layer. We prove error estimate for the asymptotic expansion up to order 1 for simple eigenvalues. This expansion can be used to obtain explicit expressions for constant index of refraction.
ex_article.pdf (336.35 Ko) Télécharger le fichier
hal-01646003 , version 1 (23-11-2017)
hal-01646003 , version 2 (03-12-2018)
  • HAL Id : hal-01646003 , version 2
Hanen Boujlida, Houssem Haddar, Moez Khenissi. The Asymptotic of Transmission Eigenvalues for a Domain with a Thin Coating. SIAM Journal on Applied Mathematics, 2018, 78 (5), pp.2348-2369. ⟨hal-01646003v2⟩
296 Consultations
374 Téléchargements
