Quantification of the unique continuation property for the heat equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Control and Related Fields Année : 2017
In this paper we prove a logarithmic stability estimate in the whole domain for the solution to the heat equation with a source term and lateral Cauchy data. We also prove its optimality up to the exponent of the logarithm and show an application to the identification of the initial condition and to the convergence rate of the quasi-reversibility method.
article_mcrf_multi_rev2.pdf (431.38 Ko) Télécharger le fichier
hal-01648045 , version 1 (24-11-2017)
Laurent Bourgeois. Quantification of the unique continuation property for the heat equation. Mathematical Control and Related Fields, 2017, 7 (3), pp.347 - 367. ⟨10.3934/mcrf.2017012⟩. ⟨hal-01648045⟩
350 Consultations
238 Téléchargements
